On the CANBUS communication, data transmit is not work regularly. How can I fix this problem ?
kadir ustun1
Hello everyone I try to communication with canbus protocol on stm32f429 discovery. but to send data and recieving data are not reguarly. for example, firs data is came, after second data recieved late.
T J
Lead
keep working on the receiver,
are you getting the fifo interrupts ?
for both fifos ? on some processors there are separate Rx_fifo interrupts.
you have to pull the data away under interrupt,
otherwise you will drop frames since the fifos are full.
kadir ustun1
I see, but firstly, I request for a packet, then I will recieve packet. but stm32f4 received very late and request very late
