POOJAN SHAH
Visitor II
May 13, 2018
Nucleo 144 BSP
  • May 13, 2018
  • 617 views
Posted on May 13, 2018 at 21:19
Hi, I am looking for bsp in keil for nucleo144 board but i am not able to find it in the latest version of the keil. Where can i find the bsp for the same? What is the procedure?
    T J
    Senior III
    May 14, 2018
    Posted on May 14, 2018 at 05:50
    Yes,
    BSP, it is not an easy request.
    Nucleo-144 is a generic form factor. Not a chip.
    there is no BSP for a form factor.
    I use the CubeMx to generate the base init code.
    Tesla DeLorean
    Guru
    May 14, 2018
    Posted on May 14, 2018 at 06:08
    The HAL/Cube trees have assorted BSP code. For Keil specific stuff you should probably contact your support/sales representative at Keil if the code you want isn't in the Packs.
