No output from DAC @STM32F103VExx
‎2012-04-10 8:50 AM
I am a university undergrad and I am designing a Digital storage oscilloscope. I need the micro controller's DAC output for DC voltage. I have seen the sample code and I know how to setup the timer, link the DMA to DAC. The code seems to be working fine on STM32VLdiscovery board, but when I run it on my STM32F103VET6 processor there is no output from DAC i.e. 0V. I would like to clarify:- I have made the board myself but I have made sure that all the connections are as per the datasheet.- I have given Vref+ as 3.3V , Vref- as GND as well. All the decaps are in place too.- All other peripheral are working fine, it is just the DAC which does not seem to be working.One problem could be with the DAC 12-bit right align config adddress i.e. &sharpdefine DAC_DHR12RD_Address 0x40007420.I reckon this should be different for STM32f103VExx than STM32f100RBxx. The code is exactly the same as ''DualModeDMA_SineWave''. Thankyou #dac-dma-tim2- Labels:
TIM
‎2012-04-10 8:59 AM
Alright. I just saw clive1's solution in one of the previous discussions(
https://my.st.com/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/Flat.aspx?RootFolder=https://my.st.com/public/STe2ecommunities/mcu/Lists/cortex_mx_stm32/dac configuration&FolderCTID=0x01200200770978C69A1141439FE559EB459D7580009C4E14902C3CDE46A77F0FFD06506F5B¤tviews=517
). apparently there was a very easy solution which does not require any DMA or timers(I don't want them either). I tried that code and it seems to be working fine now. Kudos man.- Mark as New
‎2012-04-10 9:15 AM
Are you sure it is EXACTLY the same?
The \STM32F10xFWLib\Examples\DAC\DualModeDMA_SineWave\main.c uses TIM8 not TIM2 The two DAC channels should come out of PA.4 and PA.5, and the addresses should be the same on all STM32F10X parts.Up vote any posts that you find helpful, it shows what's working..
‎2012-04-10 5:38 PM
No I am pretty sure it is TIM2, I just checked it. Thank you for you reply but anyway I am not changing the DAC output very frequently. So using DAC_SetChannelxData() works just fine, DMA is not necessary. And yeah I am aware of the DAC output pins.
-rajan
