Need suggestion for choosing microcontroller
‎2018-07-08 6:06 AM
Hi Everyone,
I am thinking of designing wireless home automation product using IoT. Can anyone suggest which STM32 series is suitable for this application. I have knowledge in stm3f4 series. So i can easily learn whatever series which is suitable my application.
#stm32-nucleo-64 #stm32-c2c- Mark as New
‎2018-07-08 6:14 AM
You may want to see this board to see if it meets your needs:
https://www.st.com/en/evaluation-tools/b-l475e-iot01a.html
Actually two versions of this board exit (different radio types).
If you think about F4 line, consider the L4 (newer, low power, etc). The board above uses L4 MCU.
‎2018-07-08 6:21 AM
It is a multi-faceted decision, and going to be dependent on your exact requirements.
For new designs consider the L4(+) or F7 depending on the amount of horse-power your application needs.
‎2018-07-08 5:37 PM
if you would like a complete solution in one Dev board, you could look at the B-L072Z-LRWAN board.
F series, Vs L series, Vs F4 , when I use the cube it is all seamless....
any chip/board will do... depending on your power budget.
