my ADC code cann't get value
daienming
Posted on March 04, 2015 at 17:41
The original post was too long to process during our migration. Please click on the attachment to read the original post.
4 REPLIES 4
Posted on March 04, 2015 at 18:39
Can't help you at all with the HAL stuff, I wish you much luck.
I will observe that unless you configure the ADC's symmetrically the sequencing of the data is likely to give you a lot of headaches.
Amel NASRI
Posted on March 09, 2015 at 11:50
Which product are you using?
Do the execution get stuck at a given level?
Are the values in ADCs registers aligned with what you expect?
-Mayla-
iumez
Posted on March 11, 2015 at 16:34
I don't know this HAL API but looking at the code you posted I see that:
1. You configured the ADC to use DMA.
2. You did not enable interrupts for the ADC.
So, how will an end of conversion event get triggered?
Posted on March 11, 2015 at 17:46
Who knows, it's a selective presentation of code, and HAL/Cube hide a lot of the detail, and has a different methodology.
