2011-04-09 02:27 AM
Multi-point Network RS-485
2011-05-17 05:31 AM
Yes. It's called Ethernet.
You need to include some kind of acknowledgment from every intended recipient, so if a collision occurs, you can do a retry. You are setting yourself up for the impossible by trying to achieve reliable communication with unknown senders and recipients. Cheers, Hal2011-05-17 05:31 AM
You should look for CAN bus , it is better solution that RS485 for your system.
