MCBSTM32C flash memory issues - punted from Keil
Options
2011-04-08 10:34 AM
Posted on April 08, 2011 at 19:34
1 REPLY 1
Options
2011-05-17 5:31 AM
Posted on May 17, 2011 at 14:31
Even without the source, you should still be able to identify why the code is faulting. Look at the disassembly, and registers.
I'm not aware of a location based issue in flash, however when running in flash and writing too it, will cause substantial stalling of the processor. This will break interrupts, USARTs, etc.
