Multi-point Network RS-485
greg_t
Posted on April 09, 2011 at 11:27
raptorhal2
Lead
Posted on May 17, 2011 at 14:31
Yes. It's called Ethernet.
You need to include some kind of acknowledgment from every intended recipient, so if a collision occurs, you can do a retry.
You are setting yourself up for the impossible by trying to achieve reliable communication with unknown senders and recipients.
Cheers, Hal
raptorhal2
Lead
Cheers, Hal
samiassaad
You should look for CAN bus , it is better solution that RS485 for your system.
