2009-07-20 10:38 PM
Mass storage device overheads.
2011-05-17 04:18 AM
Thank you ST7,
that looks useful.2011-05-17 04:18 AM
Hi all,
I'm trying to integrate the STM3210B-EVAL MSD demo software with my own application on my own design PCB. Is the controlled 1k5 pull up resistor necessary for correct operation ? Has anybody successfully used a simpler hardware implementation for the pullup than is used on the demo board ? I don't strictly need the full MSD functionality, and in practice, once an SD card is loaded with the information required, I may well be better off with either the virtual comm port, or a custom USB driver. Are there any easy to merge SCSI ~ SD card samples that aren't tightly integrated with other applications ? Thanks, Graham2011-05-17 04:18 AM
Have you looked at:
