Larger font size for HALL with STM32F469
megahercas6
Posted on December 01, 2017 at 17:08
Hello
For my project i need larger fully compatible with HALL fonts.
 I have 24 size font, but i need at least 5 times larger. Or any larger will do
Any one know where to find it ?
#fonts #hall
4 REPLIES 4
Posted on December 01, 2017 at 17:49
Probably want to look at vector fonts, large bit-map fonts will eat a lot of space.
Posted on December 01, 2017 at 18:33
Well, i did similar think for numbers. But that is only 10 numbers. i need all letters, all numbers, it can be tedious
Posted on December 01, 2017 at 18:38
I swear there was a Segger utility, saw at a seminar of F4 or F7, which would cherry pick a Windows Font, and build a data table. ie you could select a subset of the alphabet, case, numerics, etc.
Posted on December 01, 2017 at 18:44
Yikes, $2800
https://shop-us.segger.com/emWin_Font_Converter_p/3.04.00.htm
Pulling a copy of STemWin to see if it is in there, otherwise going to dig through Seminar Flash Drives...
