IWDG reset and data retention
deckhard
Hi
following a reset by the IWDG, does the SRAM1 or SRAM2 keep their content?
SRAM is retained on reset, as long as you don't lose power. Although most variables are initialized to zero or whatever their starting value is in the startup script.
4 REPLIES 4
Do you know where it is done on the IAR startup script?
deckhard
How can I save some data in SRAM and read it again following a reset?
I am not familiar with IAR.
In STM32CubeIDE, you can mark sections in the linker as NOLOAD which will prevent initialization.
