is there any example of using mbedtls and stm32f746g-discovery board?
‎2018-03-04 2:18 AM
I tried to transplant the mbedtls ssl server code for stm32f769i discovery board to stm32f746g discovery board. The error was printed on to the lcd. I.E. the headers are changed and the BSP is changed.
The error is found to be from mbedtls_mpi_grow(), from inside of which mbedtls_calloc (which in my case is calloc) returns NULL, so that screen message is:
mbedtls_pk_parse_key_returned -16912.
Is there any example of using mbedTLS with stm32f746G-discovery board?
#mbedtls-stm32f746g-discoverySolved! Go to Solution.
- Labels:
STM32F7 Series
‎2018-03-04 7:14 AM
If calloc() throws a NULL consider if your heap allocation is sufficient. In Keil builds the heap is described in stm32f7xx_startup.s
‎2018-03-04 7:14 AM
‎2018-03-04 11:42 AM
Hi Clive One, after many years, I am glad to see you again in the forum. Respect.
Yes, your answer is correct. I was modifying the linker script to increase heap size. However, another linker script file is used by the compiler instead.
The example now works. However, Chrome does not trust the certificate.
