2017-09-10 5:11 AM
The current HAL driver documentation does not have a user manual for the L496 chips. The only ones I can see are
I have V1.8.1 of the Cube library.
Is there maybe a separate link that contains the help file or am I on my own in deciphering any modules that are not in the above help.
Cheers
2017-09-10 5:27 AM
Hello.
You can go to
http://www.st.com/content/st_com/en/search.html#q=STM32L496-t=keywords-page=1
page.Choose the exact type of your MCU and inside the redirected page will find full documentation and a lot of other resources relevant to your MCU (the datasheet is at top of page)
Regards.
vf
2017-09-10 11:44 AM
Isn't the L4A6 just an L496 with AES (CRYPT) enabled? These parts are more similar than they are different. Pull the data sheet for pins/connectivity.
