2019-01-27 10:30 PM
I am using stm32 L4 family microcontroller. I enabled MSC mode to copy files from SD card mounted to device to PC. But I want to know how can I monitor the status from my code running in MCU? My program should check whether file copy in progress, completed etc..
2019-01-27 11:53 PM
You would want to monitor the sector access, mostly writes, against the file structures on those given sectors. File system would tend to update directory entry last.
Process a bit involved, not looking to carry task.
2019-09-03 4:41 AM
Thanks for the suggestions. Can you please share the link/example code which supports this (If available).
I am looking for a simple method to indicate user that file copying from device to PC is in progress by blinking LED (LED will blink only if there is file copy). Is there a simple solution?
