Internal SRAM Protect
Kim.Andy
Posted on October 29, 2015 at 05:42
Hello!!!
I want to protect any specific area of the internal SRAM(about 32KB).
So I use that area for special purpose(DB Access).
How can I do it??
Please help me...
Posted on November 03, 2015 at 18:33
Hi kim.andy.002,
Could you precise which product you are using?
For instance, for family STM32L4x6 you can proceed to write/Read protection on SRAM2. Details are available in section 2.4 (Embedded SRAM) of
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/reference_manual/DM00083560.pdf
Also, have a look at
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/application_note/DM00226247.pdf
 and
http://www.st.com/st-web-ui/static/active/en/resource/technical/document/application_note/DM00186528.pdf
-Shahrzad-
