If a MCU is packaged in a MBB, is it then necessary to put the MBB in a climate controlled cabinet in between usage? If what is the recommendation of when to put in, how many days, weeks or maybe months can be accepted before the need of a cabinet?
OJørg.1
1 REPLY 1
Guru
Unopened? From experience, months should be fine. But it ultimately depends on the environment.
Not sure what you mean by "in between usage". It sounds like you're opening the package.
See:
https://www.st.com/resource/en/application_note/an2639-soldering-recommendations-and-package-information-for-leadfree-ecopack-mcus-and-mpus-stmicroelectronics.pdf
