IDE and compiler for STM32L
ashelke
Posted on November 08, 2016 at 09:37
I've installed Coocox CoIde and ARM GCC compiler. But I cannot create new project in Coocox IDE as it shows error message in repository. I've STM32L152 discovery board and I've tried example codes provided. It shows compilation successful but the board does not work as per firmware. there is nothing displayed on LCD and LEDs don't blink. I've tried to debug the code but it sows error message
Remote debugging using 127.0.0.1:2009
0xb9337822 in ?? ()
tbreak main
Function ''main'' not defined.
continue
Continuing.
Thanks.
slimen
Posted on November 29, 2016 at 14:09
I think there is no working example with Coocox IDE.
Getting started with CoIDE from CooCox
https://st-videos.s3.amazonaws.com/CoIDE_Tutorial_with_subtitle.mp4
Please try to provide some detail in your post about exactly example you're using?
Hope this helps you.
