i2c combined example
Options
‎2015-10-10 7:53 AM
Posted on October 10, 2015 at 16:53
I would be very grateful if anyone could post some sample code to implement... i2c 7-bit protocol with combined write and read, multiple data bytes to be read in a sequence.Basic std FW library compatible sample code not involving Cube or CPAL would be preferable!!!Thanks in advance.P.S. Just wondering - the people who post those lovely clean sample snippets - where do you get them?
2 REPLIES 2
Options
‎2015-10-10 9:12 AM
Posted on October 10, 2015 at 18:12
Well I'm an engineer, and I write stuff, either from scratch, or by synthesizing what I need from other code I've written, or other code examples that don't do exactly what I want, but can be bent into shape. That and I can digest technical manuals. ST provided their own subset of examples in most of the SPL, DISCO, EVAL and Cube releases.There's really not a magic spring in the ground where they bubble out of the ether.I'm also really good at static code analysis, from machine language on up.
Options
‎2015-10-10 9:54 AM
Posted on October 10, 2015 at 18:54The problem is those examples are quite a bit complex and sometimes there are two many unknowns to be sure when you are a new guy...For example, in the case of a combined write and read protocol, typically does the Stm32 keep reading data byte after data byte after databyte automatically, until you programatically issue a stop condition?Do you happen to have a very easy to follow combined read write prototcol with multiple data bits available please, that is as simple/clear as possible?
