I would like to know the detailed parameter selection for the crystal and load capacitor used in the STM32F413VH MCU.
Rahul K V
  1.  Please help me to provide the HSE and LSE parameters to select the proper crystal and load capacitors
  2. Do you have aything in the lab tested or qualified part for the STM32F413VH MCU.
  3. What is the typical values to be chosen for the HSE crystal
You have to refer to the AN2867, section 5 Recommended resonators for STM32 MCUs / MPUs:
  • Table 6. HSE oscillators embedded in STM32 MCUs / MPUs
  • Table 7. Recommended crystal resonators for the LSE oscillator in STM32 MCUs / MPUs
Imen
Imen
4 REPLIES 4
Imen.D
Hello @Rahul K V​
Have a look at the STM32F413xG/H Datasheet :
Table 43. HSE 4-26 MHz oscillator characteristics
Table 44. LSE oscillator characteristics (fLSE = 32.768 kHz)
You can refer to this AN2867 Application note Oscillator design guide, it may helps you as guidelines for the oscillator design.
Hope my answer satisfy your need.
Imen
Imen
Lack of information in the selection table. Can you suggest part number for HSE and LSE.
Imen
Imen
Imen.D
If you are satisfied of my previous answer, please mark it as "Best", so that this thread will be marked as solved.
Imen
