I have a question about the STM32H743...
damon kutten
If this device is powered-down (i..e voltage is 0 on all rails), what impedance will be presented by the Port pins? If a pin from a powered-down STM32H743 is connected to a pin on another (fully powered) device, what current drain will occur?
11 REPLIES 11
The answer by @prain here is incorrect. You should mark Uwe Bonnes's answer as the right one.
damon kutten
To TDK:
Yes, Uwe Bonnes' answer is correct.
This was confirmed by the 10Kohm series resistor measurement that you took.
I am interested in any additional data you could obtain by using a 100Kohm resistor or 1Mohm resistor in place of the 10Kohm resistor.
