I have a question about P-NUCLEO-USB001.
HJin.2
What I want to implement is to control the role of the module between host and consumer, when modules are connected to each other. Is it possible with programming ?
If impossible with this module, what module can I use to implement that task ?
Thank you.
prain
Senior III
you may want to see USB OTG(on the go) specs​
