How to I disable the USB on the STM32L4
SSmit.13
Hi
 I am using the USB CDC on a STM32L433 with the command MX_USB_DEVICE_Init(); to communicate through the USB. In my app, I go into standby mode (by using the HAL_PWR_EnterSTANDBYMode()) command. How do I disable the USB before entering standby?  I tried the the command USBD_DeInit(&hUsbDeviceFS) , but got a hardware fault. Anyone let me know the best way to disable it?
Best Regards
Scott
STTwo-32
Hello @SSmit.13
I suggest you set the USBFSRST High then Low to reset the USB FS and set the USBFSEN Low to disable the USB FS clock.
Best Regards.
STTwo-32
STTwo-32
Hello @SSmit.13
Best Regards.
STTwo-32
That worked, many thanks
Scott
