2009-05-01 3:36 PM
How to get 64bit result from 32 x 32 multiply
2011-05-17 4:10 AM
Quote:
On 01-05-2009 at 14:54, Anonymous wrote: I have tried the typedef as in brunoalltest's post, however I get a 32 bit result with Ride7. Does the UMULL and SMULL work with inline assembler in Ride7? If so how do I do this? I´ve just tested the code with crossworks(it uses gcc, just like ride) and the arm7 simulator and it worked just like expected. My cortex-m3 board isn´t with me right now, but I´ve worked with long long casts and cortex-m3 before and it worked just fine. How are you checking the result? Hope you´re not using printf, it probably won´t support a long long variable. Use a breakpoint and check with the debuger interface instead.
