How to generate CRC-16 in javascript and validate the checksum on STM32F373
‎2023-12-16 6:13 AM
I need to generate a simple CRC16 checksum from a unit8_t array[64] in javascript and validate the checksum on the STM32F373.
I have been looking at the CRC unit and all of its options. I see STM32 use a non-standard scheme.
Does anyone know of a sample library or function examples showing how it can be done in javascript with matching c function?
Here is the javascript function i could potentially use if I can match up a c function or STM32 CRC config settings to match:
STM32F3 Series
‎2023-12-17 3:13 AM
The CRC16 checksum calculation is commonly used for error-checking purposes. The JavaScript function you provided is a CRC32 implementation, not CRC16. Here's a CRC16 implementation in JavaScript that matches a common CRC16-CCITT polynomial (0x1021) and its corresponding C function:
Javascript:
function calculateCRC16(data) {
const polynomial = 0x1021;
let crc = 0xFFFF;
for (let i = 0; i < data.length; i++) {
crc ^= (data[i] << 8);
for (let j = 0; j < 8; j++) {
crc = (crc & 0x8000) ? ((crc << 1) ^ polynomial) : (crc << 1);
return crc & 0xFFFF;
You can use this JavaScript function to calculate the CRC16 checksum for your unit8_t array[64] in JavaScript. Now, let's create a corresponding C function for STM32.
C (STM32):
#include <stdint.h>
uint16_t calculateCRC16(const uint8_t *data, uint32_t length) {
const uint16_t polynomial = 0x1021;
uint16_t crc = 0xFFFF;
for (uint32_t i = 0; i < length; i++) {
for (uint8_t j = 0; j < 8; j++) {
You can use this C function on your STM32F373 to validate the CRC16 checksum. Make sure to pass the same array of data and its length to both the JavaScript and C functions.
Note: CRC16 settings can vary, so it's important to ensure that both the JavaScript and C implementations use the same polynomial and initial CRC value for compatibility. The implementations provided use the common CRC16-CCITT polynomial (0x1021) and initial value (0xFFFF).
‎2023-12-16 4:52 PM
Depends on the polynomial, shift direction, endianess, etc there are lots of ways to implement a 16-bit CRC, even a "standard" one
// left shift, 0x1021 polynomial
uint16_t crc16_byte(uint16_t crc, uint8_t data)
int i;
crc ^= (uint16_t)crc << 8; // Apply byte to high order
for(i=0; i<8; i++)
crc = (crc << 1) ^ ((crc & 0x8000) ? 0x1021 : 0);
return(crc);
ST's 32-bit uses a "standard" polynomial, but assumes data is applied 32-bit at a time in Big Endian
uint32_t crc32_word(uint32_t crc, uint32_t data)
int i;
crc ^= data;
for(i=0; i<32; i++)
crc = (crc << 1) ^ ((crc & 0x80000000) ? 0x04C11DB7 : 0);
return(crc);
‎2023-12-17 3:13 AM
Javascript:
let crc = 0xFFFF;
C (STM32):
#include <stdint.h>
‎2023-12-18 5:00 AM
Thank you!
