How to enforce a coding standard in STMIDE ?
‎2020-11-18 2:37 AM
Is there a way to enforce a coding standard in STMIDE with some text highlighting?
i.e: "function names should be Function_Name()" etc.
What rules does STM use for their generated libraries in this case?
Does anyone recommend some plugins for this?
What standards are others trying to follow when writing their code?
- Labels:
DEBUG
‎2020-11-18 4:37 AM
"Coding standards" are totally arbitrary.
You can enforce rules like MISRA through integrating PCLint (or similar tools).
Otherwise, you can do code reviews.
‎2020-11-18 4:37 AM
‎2020-11-18 2:53 PM
There is no standard for enforcing coding standard in C or C++, partly because the language is 30+ years old and existing code out there.
Eclipse (which STM32CubeIDE is build from) can auto-format things. I find that helps quite a bit when importing messy/outside code.
Window -> Preferences -> C/C++ -> Code Style -> Formatter
Auto-formatting can be done with Source -> Format.
‎2020-11-19 12:41 AM
Handy! Thanks!
Based on this, it looks like the Code Gen is done with the formatter set to GNU. However when one installs STMIDE, the formatter is set to K&R by default.
Not a big deal, but I do bet a bunch of people get a bit OCD when they press tab in main.c and it tabs out to a different place that what is already written.
‎2020-11-19 5:48 AM
‎2020-11-22 8:54 AM
:face_with_tears_of_joy: i hear ya !
I think it would benefit the community if ST packaged some PClint or similar as an easy opt-in
