How to change the setting for the 32 MHz crystal used in the SPBTLE-1S module
yashasvi khatavkar
Posted on March 09, 2018 at 13:15
I am working with the SPBTLE-1S module. Through the BlueNrg-1 DK software, I dumped the Beacon code in it. However, in the BLE scanner application the device name is not visible.
I understand that i need to
change the setting for the 32 MHz crystal used in the SPBTLE-1S module. But i am not able to figure out where exactly the change needs to be made.
Can you please help me with this? A screen shot of where the change is to be made would help.
Thanks.
0 REPLIES 0
