2017-02-16 10:53 PM
Hello, Entering SW-DP mode can be done by following instructions in RM0351 chapter 44.3.1. External TCK/TMS sequence is required.
Is there any other way to change from JTAG-DP to SW-DP? With ARM Cortex-M3 this can be done as described in RM0008 chapter 9.4.2 AF remap and debug I/O configuration register (AFIO_MAPR)
2017-08-14 5:05 PM
Its annoying for sure and as you mention seams to be a ''tool vendor issue'' since F4/M4 dont have any AFIO_MAPR.
2017-08-14 7:57 PM
They dont have a MAPR but they do have an AFR. GPIOx->AFR[0], for instance.
GPIOA->AFR[0]: 0x20007701 00100000000000000111011100000001
PIN 0: TIM2_CH1 PIN 1: - PIN 2: USART2_TX PIN 3: USART2_RX PIN 4: - PIN 5: - PIN 6: - PIN 7: TIM3_CH2GPIOA->AFR[1]: 0x00000000 00000000000000000000000000000000
