2019-10-15 4:55 AM
I am using stm32h743z for interfacing the RGB and Infrared camera ?
My Main Question is how much total current (maximum current) we will get or we can use from 3.3 v power supply ?
I have checked the data sheet but still i cant able to find so kindly help me so that it will be helpful for my knowledge
i will also attach my datasheet . please find the attachment
2019-10-15 5:08 AM
Data sheet would have current numbers, but depends on how fast you clock things, what peripherals you have enabled, and more generally what you attach externally.
CubeMX has a current estimation tool.
You might want to measure current draw on a Nucleo board or your own prototypes.
2019-10-15 5:08 AM
