how config timer 1 to trigger timer 3 every fall edge on PWM channel 1 and channel 2
Options
2019-04-05 7:41 AM
Hello everyone
Labels:
- Labels:
TIM
Options
2019-04-12 7:41 AM
Hello @Pedram ,
It's not possible to trigger the timer 3 from timer 1 through channel 1 and channel 2 in the same time.
The source of trigger output of timer1 should be one of these:
- Reset
- Enable
- Update
- Compare Pulse (CC1IF)
- Compare - OC1REF
- Compare - OC2REF
- Compare - OC3REF
- Compare - OC4REF
You can refer to the "Timer synchronization" section in the reference manual relevant to your device.
Imen
Imen
Imen
