How can I connect an inductive sensor (with an M12 connector) to my STM32F769I-DISCO?
LleytoN
Hello everyone! I have to connect an inductive sensor to my STM32F769I-DISCO in order to count the rising edges of the signal which will correspond to the use of sheets of paper by a machine. So, especially if you have already done that, I would need some advice about the inputs of my microcontroller I may use to carry out the connection with the inductive sensor.
By the way, to count rising edges, I am wondering which functions I could use. Otherwise, do you know a specific method for doing that?
I truly thank you in advance for your help.
Sincerely,
0 REPLIES 0
