Hi can i just check, are all morpho connectors on 144 pin boards pin compatible?
HElia.2
Mike_ST
we try to keep some compatibility, at least for power/ground pins.
But for other pins they are not always the same.
It is better that you compare the boards you are interresed in by using the schematics.
Mike_ST
