BDELI.2
Help with porting FMC from STM32L4 app to STM32U5
  • March 16, 2022
  • 1020 views
Hi, I'm trying to port my code that uses the FMC to interface a LCD display. The provided configuration works on the STM32L476, but when I port it to the STM32U585 the image is offseted to the right on the display.
Main clock (and FMC clock so) are configured to the same frequency.
Can you help me finding what is the source of the problem ?
L4 code:
 FMC_Handle.Instance = FMC_NORSRAM_DEVICE;
 FMC_Handle.Extended = FMC_NORSRAM_EXTENDED_DEVICE;
 // FMC_Handle.Init
 FMC_Handle.Init.NSBank = FMC_NORSRAM_BANK1;
 FMC_Handle.Init.DataAddressMux = FMC_DATA_ADDRESS_MUX_DISABLE;
 FMC_Handle.Init.MemoryType = FMC_MEMORY_TYPE_SRAM;
 FMC_Handle.Init.MemoryDataWidth = FMC_NORSRAM_MEM_BUS_WIDTH_8;
 FMC_Handle.Init.BurstAccessMode = FMC_BURST_ACCESS_MODE_DISABLE;
 FMC_Handle.Init.WaitSignalPolarity = FMC_WAIT_SIGNAL_POLARITY_LOW;
 FMC_Handle.Init.WaitSignalActive = FMC_WAIT_TIMING_BEFORE_WS;
 FMC_Handle.Init.WriteOperation = FMC_WRITE_OPERATION_ENABLE;
 FMC_Handle.Init.WaitSignal = FMC_WAIT_SIGNAL_DISABLE;
 FMC_Handle.Init.ExtendedMode = FMC_EXTENDED_MODE_DISABLE;
 FMC_Handle.Init.AsynchronousWait = FMC_ASYNCHRONOUS_WAIT_DISABLE;
 FMC_Handle.Init.WriteBurst = FMC_WRITE_BURST_DISABLE;
 FMC_Handle.Init.ContinuousClock = FMC_CONTINUOUS_CLOCK_SYNC_ONLY;
 FMC_Handle.Init.WriteFifo = FMC_WRITE_FIFO_ENABLE;
 FMC_Handle.Init.PageSize = FMC_PAGE_SIZE_NONE;
 // Timing
 FMC_NORSRAM_TimingTypeDef FMC_Timing = {0};
 FMC_Timing.AddressSetupTime = 6;
 FMC_Timing.AddressHoldTime = 1;
 FMC_Timing.DataSetupTime = 15;
 FMC_Timing.BusTurnAroundDuration = 0;
 FMC_Timing.CLKDivision = 2;
 FMC_Timing.DataLatency = 3;
 FMC_Timing.AccessMode = FMC_ACCESS_MODE_A;
 if (HAL_SRAM_Init(&FMC_Handle, &FMC_Timing, NULL) != HAL_OK)
 display_driver_active = FALSE;
 return;
U5 code:
 // FMC_Handle.Init
 FMC_Handle.Init.NBLSetupTime = 0;
 FMC_Handle.Init.MaxChipSelectPulse = DISABLE;
 // Timing
 FMC_Timing.DataHoldTime = 0;
 return;
Best answer by Tesla DeLorean
Check pinning
Check schematics
Check expectations of display, and why shift might be occurring
Perhaps stick a scope on the interface, and be sure the clocks, and dividers are consistent with expectations, and that timing is in fact correct.
Try write and read back of display side registers, and memory buffers
If you continue to struggle perhaps hook up a logic analyzers to more clearly define the problem/issue faced.
Tesla DeLorean
Tesla DeLoreanBest answer
Guru
March 16, 2022
Check pinning
Check schematics
BDELI.2
BDELI.2Author
The problem was not linked to the FMC, it was an interrupts that was not linked to the right EXTI... Thank you for your advices anyway ;)
