Help with PC8 blinking LED - STM32F051
miriam
Posted on September 28, 2016 at 04:36
I try to run the following program on KEIL MDK 5.0:
&sharpinclude ''stm32f0xx.h''
int main(void){
volatile unsigned int i=0;
RCC -> AHBENR |= (i<<19);
GPIOC ->MODER |= (i<<16); // mode
GPIOC ->ODR |= (i<<8); // output data is ON
  while (1)  {
for (i=0; i<1000000; i++)
GPIOC ->ODR &= (i<<8); // output data is OFF
From some reason I don't see the BLUE LED blinking.
Anyone know why?
Thanks,
Miri
#stm32f051-stm32-stm32f0
16 REPLIES 16
miriam
Posted on September 29, 2016 at 18:16
I tried this as well:
GPIOC ->ODR |= 1;
GPIOC ->ODR |= 0;
But nothing happen with the leds.
Posted on September 29, 2016 at 18:27
GPIOC ->ODR |= 1;
GPIOC ->ODR |= 0;
Is PC0 connected to an LED, and configured as an output?
Or'ing something with zero isn't going to do anything useful.
GPIOC ->ODR |= 256; // PC8 Set
GPIOC ->ODR &= ~256; // PC8 Clear
miriam
Posted on September 29, 2016 at 18:33
I want to use the onboard led PC8 or PC9.
I changed it to:
But nothing happen.
miriam
Posted on September 29, 2016 at 18:40 What is a good configuration of PC8 to output?
GPIOC ->MODER |= (1<<
16
); // mode Output
or
GPIOC ->MODER |= 256
; // mode Output
Posted on September 29, 2016 at 18:41
Perhaps you could use the debugger and step through the code whilst looking at the Peripheral Registers in the viewer?
Posted on September 29, 2016 at 18:49
GPIOC ->MODER |= (1<<16); // mode Output
or
GPIOC ->MODER |= 256; // mode Output
If you look at the Reference Manual, it indicates that there are two bits for each pin, which is why it shifts the 1 by 16 and not 8.
If you choose to program at the register level you're going to have to be very familiar with the manual and the descriptions of the registers at a bit level. Consider using the Standard Peripheral Library (SPL)
You might need some additional delay between enabling the GPIOC clock, and writing to the peripheral.
Walid FTITI_O
Senior II
Posted on September 29, 2016 at 20:04
Hi miri,
To start developping STM32 application you can use either standard peripherals library (you can download STM32F0xx standard peripheral library from this
http://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32-standard-peripheral-libraries/stsw-stm32048.html
) or you can use the Hal library called STM32Cube ( you can download STM32CubeF0 from this
http://www.st.com/content/st_com/en/products/embedded-software/mcus-embedded-software/stm32-embedded-software/stm32cube-embedded-software/stm32cubef0.html
For GPIO toggling follow these path:
* In standard peripherals library:  STM32F0xx_StdPeriph_Lib_V1.5.0\Projects\STM32F0xx_StdPeriph_Examples\GPIO\GPIO_IOToggle
* In STM32CubeF0: projects are classified per board : for example for the STM32F030R8-Nucleo follow this example path:
STM32Cube_FW_F0_V1.6.0\Projects\STM32F030R8-Nucleo\Examples\GPIO\GPIO_IOToggle
-Hannibal-
