help STM32-P103 RS232
‎2013-03-25 2:18 PM
Hi i
would like
to use the circuit
MAX3232
RS232adapter
) to connect twoPORT
RS232
with this
circuit
using just
TX and RX
only
if possible
this experience?
and thank you- Mark as New
‎2013-03-25 3:02 PM
There seems to be a language barrier here. Perhaps it would be easier to explain your requirement with a diagram...?
‎2013-03-25 4:15 PM
Here is a
that
represents
my problem
if
possible to do this
configuration?
?? ________________ Attachments : Doc1.pdf : https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I1An&d=%2Fa%2F0X0000000bjO%2FMxvFcOji_FYohzLHw5WB39F3L3WIkazQ.unp2P0.vmY&asPdf=false- Mark as New
‎2013-03-25 11:47 PM
By ''STM32-P103'' I assume you mean this:
https://www.olimex.com/Products/ARM/ST/STM32-P103/
Note that it has one RS232 port already - so you only need to add one other. Study the documentation to see where the other UART port pins can be accessed on the various connectors on the board...A complex system designed from scratch never works and cannot be patched up to make it work.
‎2013-03-26 1:31 AM
I see you have also posted the same question in a different thread:
/519d41ef
