2026-05-21 3:28 PM
Can someone pls help me fill this information out for STM32H753VIH6? Thank you.
Model Name | Check Group | 1 (注1) | 2 (注2) | 3 (注3) | 4 (注5) |
Ministerial Ordinance Article Number | 第6条第一号イ | 第6条第一号ロ | 第6条第一号ハ | ||
Check Items | Presence or Absence of Radiation-Hardened Design | Design Intent | Rated Operating Temperature Range (°C) |
Whether or not compound semiconductors are used (Note 4) | Maximum Clock Frequency (Note 4) (MHz) | ||||
Determination Criteria | (i) Total Ionizing Dose: (Applicable) ≧ 5x10³ Gray (Si) (ii) Dose Rate: (Applicable) ≧ 5x10⁶ Gray (Si)/s (iii) Neutron Flux (1 MeV equivalent): (Applicable) ≧ 5x10¹³ (particles/cm²) | Is it designed for civil automobiles or railway vehicles? | (i) (Applicable) > 125°C (ii) (Applicable) < -55°C (iii) (Applicable) = -55 to 125°C | (Applicable) = Formed from compound semiconductors | (Applicable) > 40 |
(Filling Example) ABCxxxxx | - | No | 0~85 | (Compound) | 30 |
STM32H753VIH6 |
Model Name | Check Group | 1(注1) | 2(注2) | 3(注3) | 4 (注4) | ||||
Ministerial Ordinance Article Number | 第6条第一号イ | 第6条第一号ロ | 第6条第一号ホ(一) | ||||||
| 1 | 2 | 3 | 4 | 5 | ||||
Design Intent |
Rated Operating Temperature Range (°C) | Resolution (bit) | <10bit resolution 8bit≦ | <12bit resolution 10bit≦ | <14bit resolution 12bit≦ | <16bit resolution 14bit≦ |
resolution 16bit≦ |
| Sampling |
| Sampling |
| Sampling |
| Sampling |
| Sampling |
Determination Criteria | (i) Total Ionizing Dose: (Applicable) ≧ 5x10³ Gray (Si) (該)≧5x10⁶ グレイ(Si)/s (ii) Dose Rate: (Applicable) ≧ 5x10⁶ Gray (Si)/s (iii) Neutron Flux (1 MeV equivalent): (Applicable) ≧ 5x10¹³ (particles/cm²) | Is it designed for civil automobiles or railway vehicles? | (i) (Applicable) > 125°C (ii) (Applicable) < -55°C (iii) (Applicable) = -55 to 125°C |
>1.3
(Giga samples/sec) |
>600
(Mega samples/sec) |
>400
>250
>65
(Mega samples/sec) | |
(example)ABCxxxxx | - | No | 0~85 | 10 | - | 150 | - | - | - |
STM32H753VIH6 |
2026-05-22 1:09 AM
Many (most?) of those things will be in the datasheet; eg, operating temperature range, maximum frequencies.
https://www.st.com/en/microcontrollers-microprocessors/stm32h753vi.html#documentation
2026-05-22 6:31 AM
Hello @jamieguinto and welcome to the community;
Could you please look at How to write your question to maximize your chance... - STMicroelectronics Community and give more details about your issue or request.
Thank you.
Kaouthar
