Hello! What is the difference between output compare and output compare no output in Cube IDE? Can I use output compare no output to trigger ADC?
Options
‎2021-06-26 2:23 PM
Options
‎2021-06-26 3:41 PM
No output means the signal isn't piped out to a pin, but everything else happens, so yes you can still use it to trigger the ADC.
Options
‎2021-06-26 11:46 PM
Thank you!
