GPIO port pull ups enabled
nanayakkaraan
Posted on November 05, 2010 at 09:32
lowpowermcu
Posted on May 17, 2011 at 14:13
Hi ANN,
When you enable the pull-up on a pin configured in input you will get the bit in IDR register set to ''1''. the pin can be set to low level by external component. I think that avoids to use external pull-ups on pins so less external components.
Herzlich,
MCU Lüfter
