GPIO Pins to ADC Channels
Options
2010-08-26 8:44 PM
Posted on August 27, 2010 at 05:44
3 REPLIES 3
Options
2011-05-17 5:04 AM
Posted on May 17, 2011 at 14:04 The original post was too long to process during our migration. Please click on the provided URL to read the original post. https://st--c.eu10.content.force.com/sfc/dist/version/download/?oid=00Db0000000YtG6&ids=0680X000006I6Xv&d=%2Fa%2F0X0000000bqM%2F0EIty1FpOgVgwTCVsYJgkXI6gBSJDW.5znfIV4f6cs0&asPdf=false
Options
2011-05-17 5:04 AM
Hola;
cual es el soft que usted utiliza para hacer esta confilación? ya que utilizando IAR no puedo lograr la conpilación sin errores. Usted tendría un ejemplo conpilable sobre el mismo tema pero pero en IAR 4? Gracias.Options
2011-05-17 5:04 AM
Usted tendría un ejemplo conpilable sobre el mismo tema pero pero en IAR 4? You're going to need to add in the required #include files, and place it in a project framework/template based around the ST firmware library. The code looks to be reasonably viable for IAR or Keil. If you want help with specific compiler error messages, please list them, but I suspect you just have some include/library related issues.
