floating point operations
Options
2008-03-18 7:50 PM
Posted on March 19, 2008 at 03:50
Options
2011-05-17 3:26 AM
Posted on May 17, 2011 at 12:26I used this ftoa fun it doesnt working. same function was working in PC version compiler is there any options to add for floating point operations? i also add the options like -mfpu=vfp -mfloat-abi-softfp but it also didnt work how to resolve this? let me know int my_ftoa (float x, char *str, char prec, char format) { /* converts a floating point number to an ascii string */ /* x is stored into str, which should be at least 30 chars long */ int ie, i, k, ndig, fstyle; double y; //if (nargs() != 7) // print_text(''ftoa ''); //ndig = ( prec<=0) ? 7 : (prec > 22 ? 23 : prec+1); ndig = prec+1; if(format == 'f' || format == 'F') fstyle = 1; else fstyle = 0; /* print in e format unless last arg is 'f' */ ie = 0; /* if x negative, write minus and reverse */ if ( x < 0) { *str++ = '-'; x = -x; } // put x in range 1 <= x < 10 if (x > 0.0) while (x < 1.0) { x =x*10.0; ie--; } while (x >= 10.0) { x = x/10.0; ie++; } /* in f format, number of digits is related to size */ if (fstyle) ndig =ndig + ie; /* round. x is between 1 and 10 and ndig will be printed to right of decimal point so rounding is ... */ for (y = i = 1; i < ndig; i++) y = y/10.0; x =x+ y/2.0; //if (x >= 10.0) {x = 1.0; ie++;} /* repair rounding disasters */ /* now loop. put out a digit (obtain by multiplying by 10, truncating, subtracting) until enough digits out */ /* if fstyle, and leading zeros, they go out special */ if (fstyle && ie { *str++ = '0'; *str++ = '.'; if (ndig < 0) ie = ie-ndig; /* limit zeros if underflow */ for (i = -1; i > ie; i--) *str++ = '0'; } for (i=0; i < ndig; i++) { k = x; *str++ = k + '0'; if (i == (fstyle ? ie : 0)) /* where is decimal point */ *str++ = '.'; x =- (y=k); x =x*10.0; } /* now, in estyle, put out exponent if not zero */ if (!fstyle && ie != 0) { *str++ = 'E'; if (ie < 0) { ie = -ie; *str++ = '-'; } for (k=100; k > ie; k =k/10); for (; k > 0; k =k/10) { *str++ = ie/k + '0'; ie = ie%k; } } *str = '\0'; return 0; } and I want to convert a floating point to an integer, store the value in int format, in the above functions it hangs how to resolve this problem? can anyone help me? regards nagendra
