Fail to read from EEPROM
Posted on September 10, 2011 at 11:17
When I read from EEPROM multiple times, it succeeds to read for the first time but then it fails always even if I reload the project. To solve this issue I have to power off the board (unplug the USB cable). When I debug it I found that the EEPROM entered a BUSY STATE and it never goes out of it unless you power it off. I have 2 questions: 1) what is the right way to read from EEPROM without getting a BUSY? 2) when a BUSY occurs, how to revert to idle state without power off? Regards, Celo
