F411 System Clock Configuration with Internal Clock
HDaji.1
I have been working F411RE Nucleo board with LL library for quite some time.
I found the sample code for SystemClock_Config uses external oscillator as showed below. I wonder if there is any sample for internal oscillator.
  /* Enable HSE oscillator */
  LL_RCC_HSE_EnableBypass();
  LL_RCC_HSE_Enable();
  while(LL_RCC_HSE_IsReady() != 1)
  /* Set FLASH latency */
  LL_FLASH_SetLatency(LL_FLASH_LATENCY_3);
  /* Main PLL configuration and activation */
  LL_RCC_PLL_ConfigDomain_SYS(LL_RCC_PLLSOURCE_HSE, LL_RCC_PLLM_DIV_8, 400, LL_RCC_PLLP_DIV_4);
  LL_RCC_PLL_Enable();
  while(LL_RCC_PLL_IsReady() != 1)
  /* Sysclk activation on the main PLL */
  LL_RCC_SetAHBPrescaler(LL_RCC_SYSCLK_DIV_1);
  LL_RCC_SetSysClkSource(LL_RCC_SYS_CLKSOURCE_PLL);
  while(LL_RCC_GetSysClkSource() != LL_RCC_SYS_CLKSOURCE_STATUS_PLL)
  /* Set APB1 & APB2 prescaler */
  LL_RCC_SetAPB1Prescaler(LL_RCC_APB1_DIV_2);
  LL_RCC_SetAPB2Prescaler(LL_RCC_APB2_DIV_1);
  /* Set systick to 1ms */
  SysTick_Config(100000000 / 1000);
  /* Update CMSIS variable (which can be updated also through SystemCoreClockUpdate function) */
  SystemCoreClock = 100000000;
HDaji.1
This is the LL code generated by CubeIDE that is working.
void SystemClock_Config(void)
  LL_FLASH_SetLatency(LL_FLASH_LATENCY_0);
  while(LL_FLASH_GetLatency()!= LL_FLASH_LATENCY_0)
  LL_PWR_SetRegulVoltageScaling(LL_PWR_REGU_VOLTAGE_SCALE1);
   /* Wait till HSE is ready */
  LL_RCC_SetAPB1Prescaler(LL_RCC_APB1_DIV_1);
  LL_RCC_SetSysClkSource(LL_RCC_SYS_CLKSOURCE_HSE);
   /* Wait till System clock is ready */
  while(LL_RCC_GetSysClkSource() != LL_RCC_SYS_CLKSOURCE_STATUS_HSE)
  LL_Init1msTick(25000000);
  LL_SetSystemCoreClock(25000000);
  LL_RCC_SetTIMPrescaler(LL_RCC_TIM_PRESCALER_TWICE);
HDaji.1
I have managed to change to internal clock as showed below. Somehow LL_mDelay is much slower. Maybe due to slower clock source?
	LL_RCC_HSE_DisableBypass();
  //LL_RCC_HSE_EnableBypass();
  //LL_RCC_HSE_Enable();
	LL_RCC_HSI_Enable();
	//while(LL_RCC_HSE_IsReady() != 1)
	while(LL_RCC_HSI_IsReady() != 1)
  //LL_RCC_PLL_ConfigDomain_SYS(LL_RCC_PLLSOURCE_HSE, LL_RCC_PLLM_DIV_8, 400, LL_RCC_PLLP_DIV_4);
  LL_RCC_PLL_ConfigDomain_SYS(LL_RCC_PLLSOURCE_HSI, LL_RCC_PLLM_DIV_8, 400, LL_RCC_PLLP_DIV_4);
  //LL_RCC_SetSysClkSource(LL_RCC_SYS_CLKSOURCE_PLL);
  LL_RCC_SetSysClkSource(LL_RCC_SYS_CLKSOURCE_HSI);
  //while(LL_RCC_GetSysClkSource() != LL_RCC_SYS_CLKSOURCE_STATUS_PLL)
  while(LL_RCC_GetSysClkSource() != LL_RCC_SYS_CLKSOURCE_STATUS_HSI)
HDaji.1
In fact my PCB board has an external clock. The SystemClock_Config using HAL library works well, but SystemClock_Config using LL library does not. Can anyone tell the key difference?
  __HAL_RCC_PWR_CLK_ENABLE();
  __HAL_PWR_VOLTAGESCALING_CONFIG(PWR_REGULATOR_VOLTAGE_SCALE1);
  /** Initializes the CPU, AHB and APB busses clocks
  RCC_OscInitStruct.OscillatorType = RCC_OSCILLATORTYPE_HSE;
    Error_Handler();
  RCC_ClkInitStruct.SYSCLKSource = RCC_SYSCLKSOURCE_HSE;
  if (HAL_RCC_ClockConfig(&RCC_ClkInitStruct, FLASH_LATENCY_0) != HAL_OK)
    Error_Handler();
HDaji.1
