Eray Eray
Visitor II
January 4, 2017
External Clock Problem
  • January 4, 2017
  • 1 reply
  • 598 views
Posted on January 04, 2017 at 09:39
   I am using STM32CubeMX and I want to use external crystal for clock. However, I face some problems,
1) I set Baudrate 9600 for uart2 and send data to computer but in computer I can read the data with 4800 baudrate via teraterm.
2) I use bluetooth module(HC-06) and I set baudrate 9600 for uart1 but I cannot read this data any baudrate.
   I think, STM32CubeMX cannot set their clock frequencies.
    Is there anyone face same problem or how can I fix this ? Any ideas ?
   I use L053r8 chip
#external-clock
    1 reply
    Nesrine M_O
    Posted on January 04, 2017 at 11:27
    Hi
    Kacar.Eray
    • Have you try toOutput SYSCLK on MCO pin to be sure about your clock settings?
    • Could you please check the
      Baud rate register (USART_BRR)?
    • could you please precise the over sampling method that you use?
    • The auto baud rate detection mode is activated in your case?
    • I recommend you to have a look to these examples to have idea about USART
      settings:
      STM32Cube_FW_L0_V1.7.0\Projects\STM32L053R8-Nucleo\Examples\UART
    -Nesrine-
