Ethernet on the F765 and F767.
Asantos
Posted on October 14, 2016 at 22:06
Has someone put the ethernet to work in the F765 or in the F767 microcontrollers, in a custom or development board?
Ari.
Amel NASRI
Posted on October 28, 2016 at 10:29
Hi mendes.ari.001,
Please note that there was a limitation using RMII on devices Revision A and it was fixed in Revision Z (see
http://www.st.com/content/ccc/resource/technical/document/errata_sheet/group0/23/a6/11/0b/30/24/46/a5/DM00257543/files/DM00257543.pdf/jcr:content/translations/en.DM00257543.pdf
for more details).
If you aren't in the same conditions as the errata sheet, you need to do farther investigation on your case and keep us informed if you need help.
-Mayla-
Asantos
Posted on October 29, 2016 at 13:16
Thanks Mayla.
  Are the revision Z already in production?
  There will be NUCLEO-F767ZI with revision Z chips? When?
Ari.
