Enternal Interrupt Not Triggering
Options
2013-01-10 1:59 PM
Posted on January 10, 2013 at 22:59
I would like to be interrupted every time
an external input
occurs
line is take
n high on each
data tran
sfer to another chip
.I can see the external input on the scope
but I don't get a
n interrupt. Am I not setup correctly?
I'm using a STM32F4.
void
TriggerConfig(
void
/* PA.02 (INPUT) */
/* Enable System Clock */
RCC_APB2PeriphClockCmd(RCC_APB2Periph_SYSCFG, ENABLE);
/* Enable HW Peripheral Clock */
RCC_AHB1PeriphClockCmd(RCC_AHB1Periph_GPIOA, ENABLE);
/* GPIO configuration : PA.02 */
GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN;
GPIO_InitStructure.GPIO_Speed = GPIO_Speed_2MHz;
GPIO_InitStructure.GPIO_PuPd = GPIO_PuPd_NOPULL;
GPIO_Init(GPIOA, &GPIO_InitStructure);
/* Connect GPIO to EXT */
SYSCFG_EXTILineConfig(EXTI_PortSourceGPIOA, EXTI_PinSource2);
/* External Trigger */
EXTI_InitTypeDef EXTI_InitStructure;
EXTI_InitStructure.EXTI_Line = EXTI_Line2;
EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;
EXTI_InitStructure.EXTI_LineCmd = ENABLE;
EXTI_Init(&EXTI_InitStructure);
/* Enable the global Interrupt */
NVIC_InitTypeDef NVIC_InitStructure;
NVIC_InitStructure.NVIC_IRQChannel = EXTI2_IRQn;
NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0x0F;
NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0x0F;
NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
NVIC_Init(&NVIC_InitStructure);
void
EXTI2_IRQHandler(
void
if
(EXTI_GetITStatus(EXTI_Line2) != RESET)
printf
''Gottcha!''
/* Clear the interrupt */
EXTI_ClearITPendingBit(EXTI_Line2);
NVIC_ClearPendingIRQ(EXTI2_IRQn);
1 REPLY 1
Options
2013-01-10 3:40 PM
Posted on January 11, 2013 at 00:40
Doesn't look unreasonable.
Are you perhaps using C++? That might given name mangling issues with the IRQ handler and fail to be the routine in the vector table. Perhaps review the .MAP file. What debugging have you done, if you break execution after the external signal where is the CPU executing?
