EM-STM32C - EVALUATION KIT, F107, ETHERNET, TFT LCD, USB for 17$
Posted on March 16, 2018 at 16:13
I know F1 it ancient hardware but I found the board interesting:
http://www.newark.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&langId=-1&urlRequestType=Base&partNumber=64R5913&storeId=10194
12 REPLIES 12
Andrew Neil
Posted on March 16, 2018 at 17:01
I'd have thought $17 would be worth it just for the display!
However
7 sections of numerical code tubes
doesn't give much hope for any comprehensible documentation!
Andrew Neil
Posted on March 16, 2018 at 17:23
and uVision-
3
is really ancient software!!
Posted on March 16, 2018 at 17:08
I managed to find a schematic (I hope it's the right one). We will see.
Posted on March 16, 2018 at 17:11
3.3.12 7 sections of numerical code tubes
The Board has four 7 sections of numerical code tubes. They can be used to display time, data or other numbers.
Posted on March 16, 2018 at 18:43
Looks like the Embedded Pi boards are going clearance too.
http://www.newark.com/embest/embedded-pi/i-o-bridge-rpi-arduino-arm/dp/67W2379?st=arduino%20i/o%20shield
https://community.st.com/0D50X00009XkVx2SAF
Posted on March 16, 2018 at 17:57
I hope I'll manage to develop something useful using Keil v5. Had chance to do it for other STM32F1 boards.
Posted on March 16, 2018 at 18:07
Of course - as far as Keil (or any other compiler) is concerned, it's jut a Cortex-M3.
Does the board have SWD, though - or do you need an actual ST-Link with real JTAG ... ?
Posted on March 16, 2018 at 18:12
20-pin JTAG. I have Segger so I should not be a problem, I guess.
Posted on March 16, 2018 at 18:15
I also ordered a couple of
http://www.newark.com/stmicroelectronics/stm3240gprimer/evaluation-board-mcu/dp/87T3830
just to split the shipment cost with other guys.
I wonder what is your opinion about this piece of hardware
