Echo cancellation on STM32F769I-DISCO
PascalB
I need to perform a noise reduction and echo cancellation on an audio signal coming from an analog microphone and going out on a loudspeaker in order to make VOIP between 2 boards.
I have an STM32F769I-DISCO board containing an STM32F769, a WM8994 codec, a "line in" and a "line out" connector.
Will my application be possible with this board? Are there any example projects close to it that manage echo cancellation running on this board? If not, which component could I use for this application?
Thanks in advance,
Pascal
