Does USB OTG Require Pullup on DP line?
Options
2015-11-01 8:02 PM
Posted on November 02, 2015 at 05:02 Does the Discovery board use pull-up or pull-down resistors on the USB OTG? Schematic says it doesn't, the USB standard says it's required. Any guesses? Thanks...
1 REPLY 1
Options
2015-11-10 3:07 AM
Posted on November 10, 2015 at 12:07
Hi roofie01,
There are internal pullup available within the USB peripheral. So there is no need to add external ones.This what explains why you don't see them in discovery board schematic.-Mayla-To give better visibility on the answered topics, please click on Accept as Solution on the reply which solved your issue or answered your question.
