2016-03-21 1:27 PM
Does CubeMx implement the workarounds described on the erratas file or that is the user's job?
2016-03-21 4:20 PM
Well perhaps some of them. Usually protects you from the hazards related to the AHB/APB clock enables, and TIM->SR flag clearing etc.
Probably less so the Cortex's tail chaining pipeline hazard.I'd recommend you keep the errata in mind as you code your solution. Cube is just a frame-work creator, assuming it is much else is perhaps dangerous.2016-10-07 3:12 AM
Dear user,
it is part of our process now. Starting with STM32CubeMX 4.17 (coming out soon), STM32CubeMX shall reveal MCUs limitations as listed in the errata sheet.
Best regards
