chichvarin
DMA double buffering
  • May 17, 2012
  • 712 views
Posted on May 17, 2012 at 15:33
Hi everyone. While reading ST technical documentation i haven't realised whether there exists a simple way to find out which one of buffers is in use in interrupt routine without keeping count, some reliable way?
#dma-double-buffer-memory-target
raffael
Posted on May 21, 2012 at 09:04
I'm using the following command to determine which memory block has to be processed:
DMA_GetCurrentMemoryTarget
if( DMA_GetCurrentMemoryTarget(DMA2_Stream0) == 0 ) {
} else {
Best.
chichvarin
Posted on May 21, 2012 at 16:41
Thank you very much for your advice. It's very helpfull!
