Difference between hardware SDIO and SPI for SD interface?
Options
‎2008-07-17 10:18 AM
Posted on July 17, 2008 at 19:18
2 REPLIES 2
Options
‎2011-05-17 3:39 AM
Posted on May 17, 2011 at 12:39
STM32 with 256K flash or above gets hardware SDIO , while 128K or below
using SPI to do SD access! major difference between these 2 access? maximum SD capacity access different? possible compatible issue? support future SD card with larger capacity?Options
‎2011-05-17 3:39 AM
Hi Kuni,
For SDIO, STM32 High density is fully compatible with SDIO V2.0 and V1.1 and also supports SDHC with larger capacity > 4GBytes and more. Regards, STOne-32.
